private ESRI.ArcGIS.Geometry.ISpatialReference3 pSR; private void cmdSetReference_Click(System.Object sender, System.EventArgs e) { ESRI.ArcGIS.CatalogUI.ISpatialReferenceDialog2 pSRDialog = new ESRI.ArcGIS.CatalogUI.SpatialReferenceDialog(); pSR = pSRDialog.DoModalCreate(false, false, false, My.ArcMap.Application.hWnd); if ((pSR != null)) { if (!pSR is ESRI.ArcGIS.Geometry.IGeographicCoordinateSystem2 & !pSR is ESRI.ArcGIS.Geometry.IProjectedCoordinateSystem5) { System.Windows.Forms.MessageBox.Show("Please select a projected or geographic coordinate system. ", "Unknown Coordinate System", System.Windows.Forms.MessageBoxButtons.OK, System.Windows.Forms.MessageBoxIcon.Exclamation); } } }
private void cmdSub_Click(object sender, EventArgs e) { string strdatabasePath = "C:\\" + @txtProject.Text + "\\Survey\\Data_Table\\" + @txtDatabase.Text + @txtSub.Text; if (!Directory.Exists(strdatabasePath) == false) { MessageBox.Show("Destination Directory was not Found, Please Create the Directory First"); } IWorkspaceFactory pWSF = new FileGDBWorkspaceFactoryClass(); Boolean blsWorkspace = pWSF.IsWorkspace("C:\\" + @txtProject.Text + "\\Survey\\GeoDatabase\\" + @txtDatabase.Text + "\\" + @txtDatabase.Text + ".gdb"); if (blsWorkspace == true) { IWorkspace pWorkspace = pWSF.OpenFromFile("C:\\" + @txtProject.Text + "\\Survey\\GeoDatabase\\" + @txtDatabase.Text + "\\" + @txtDatabase.Text + ".gdb", 0); IFeatureWorkspace pfeatureWorkspace = (IFeatureWorkspace)pWorkspace; IEnumDatasetName pEnumDatasetName = pWorkspace.get_DatasetNames(esriDatasetType.esriDTFeatureDataset); IDatasetName pDatasetName = pEnumDatasetName.Next(); while (pDatasetName != null) { pEnumDatasetName = (IEnumDatasetName)pDatasetName; string theDatasetName; int theValue; Boolean f = groupBox2.Focused; int theVal = Convert.ToInt32(f); while (pDatasetName == null) { theDatasetName = pDatasetName.Name; if (theDatasetName == txtSub.Text) { theValue = 1; pDatasetName = pEnumDatasetName.Next(); if (theValue != 1) { ISpatialReferenceDialog pSpaRefDlog = new SpatialReferenceDialogClass(); ISpatialReference m_SpaRef = pSpaRefDlog.DoModalCreate(true, true, true, theVal); } MessageBox.Show("FeatureDataset Created"); } else { MessageBox.Show("No Spatial Reference Found, Feature Dataset was Not Created"); } } } } }
if (theValue != 1) { ISpatialReferenceDialog pSpaRefDlog = new SpatialReferenceDialogClass(); ISpatialReference m_SpaRef = pSpaRefDlog.DoModalCreate(true, true, true, theVal); IName nameObj = pDatasetName as IName; IDataset dataset = nameObj.Open() as IDataset; IGeoDataset pGeoDataset = dataset as IGeoDataset; IGeoDatasetSchemaEdit pGDsEdit = pGeoDataset as IGeoDatasetSchemaEdit; pGDsEdit.AlterSpatialReference( m_SpaRef); }
