I have this layers (Series of images)
inside each one, there are this:
I need this information (now empty) to show in a infowindow. How can access to this?
Rolando,
You can get this date by getting the description property of a FeatureLayer:
FeatureLayer | API Reference | ArcGIS API for JavaScript 3.18 | Description
Or you can use esriRequest to get this as well.
Robert,Can you explain me this example?At this lines:// InfoWindow expects an array of features from each deferred// object that you pass. If the response from the task execution// above is not an array of features, then you need to add a callback// like the one above to post-process the response and return an// array of features.map.infoWindow.setFeatures([deferred]);
yes, it has comments but I don't understand.Instead, var deferred = identifyTask .execute(identifyParams) .addCallback(function (response) {..} , I'm making, identifyTask.execute(identifyParams, function (response) {..} .
Instead .setFeatures([deferred]), I'm sending .setFeatures(feature), where feature = response[0].feature, and is saving the infoTemplate.
When I click the map, the infoWindow content is 'No information', Why?
Thanks a lot.
Thanks Rober, It was really helpful.
OK that is a very different question then. You would use the IdentifyTask for that.
thanks Robert,
But I want to know anything else:Suppose that I click on map, right? So, the map is composed by little rectangs [0,1,2 ... sublayers or really, satellital images] at respective places. How can I get what layer (or rectangle of satellital image) I am clicking?
(sorry, if this question should not be here, I will republish it again)
