Hola Rachel,I wanted to make sure I had understood your recent post. You are able to directly add a .pmf into ArcMap or drag and drop it into ArcMap, and then save it as a .mxd. I was asking because I just tested this work flow in 10.0.5 & 10.1, and I am not able to add directly a .pmf file (unsupported data format). If I attempt to drag and drop the .pmf file directly into ArcMap, I receive an error, so if you would please let us know your work flow. Gracias, Rachel![ATTACH=CONFIG]16565[/ATTACH]
Hi,The ability to open a .pmf file in ArcMap has to be specified when the file is published.In the Publisher Settings dialog, on the Application tab, there is a check box: "Open in ArcReader only" which must be unchecked, and another: "Unrestricted access to contents of Published Map" ("Check this box to open the published map in any appropriate ArcGIS application") which must be checked.These settings reset to default so you have to set them each time you publish a map.Hope that helps,Dan
