Here's a step by step guide, I'm sure its a small thing you missed, but projection should not matter.1) Have shapefile and bring into Geodatabase (SDE)2) Right Click > Add Global IDs, also Register as Versioned (if you want to edit feature in ArcMap)3) Create an mxd with your Feature Class4) Double click on the data frame, Data Frame tab > set your extents, I personally click on "Other" > Specify Exten > Ok > Ok > Save mxd5) Open ArcCatalog > right click on ur mxd > Public to ArcGIS Server > Put checkmark for Mobile Access6) Open Mobile Project Center > Add Layers (Operational) > Find your service > AddHopefully one of these steps is something you missed, if not, please tell us what you did, step by step so we can determine if there's something wrong with your procedure.Thanks,Akhil P.
I read through this PDF, am I correct in understanding that the only way to publish a map online and have people contribute data from the field directly into an interactive online map is through Arc Server?
