<\/HEAD>
Ik gebruik Portal for ArcGIS 10.6.1 en probeer een Arcade Attribute Expression te gebruiken om een pop-up te vullen. Hier is mijn syntax:<\/P>
<\/P>
<SPAN class="string token">"De afstand voor de "<\/SPAN> <SPAN class="operator token">+<\/SPAN> <SPAN class="token function">Proper<\/SPAN><SPAN class="punctuation token">(<\/SPAN>$feature<SPAN class="punctuation token">.<\/SPAN>FUNCTCLASS<SPAN class="punctuation token">)<\/SPAN> <SPAN class="operator token">+<\/SPAN> <SPAN class="string token">" wegklasse is "<\/SPAN> <SPAN class="operator token">+<\/SPAN>
<SPAN class="token function">Decode<\/SPAN><SPAN class="punctuation token">(<\/SPAN>$feature<SPAN class="punctuation token">.<\/SPAN>FUNCTCLASS<SPAN class="punctuation token">,<\/SPAN>
<SPAN class="string token">"FREEWAY"<\/SPAN><SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"150 feet "<\/SPAN><SPAN class="punctuation token">,<\/SPAN>
<SPAN class="string token">"PRINCIPAL ARTERIAL"<\/SPAN><SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"150 feet "<\/SPAN><SPAN class="punctuation token">,<\/SPAN>
<SPAN class="string token">"MINOR ARTERIAL"<\/SPAN><SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"100 feet "<\/SPAN><SPAN class="punctuation token">,<\/SPAN>
<SPAN class="string token">"MAJOR COLLECTOR"<\/SPAN><SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"100 feet "<\/SPAN><SPAN class="punctuation token">,<\/SPAN>
<SPAN class="string token">"MINOR COLLECTOR"<\/SPAN><SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"75 feet "<\/SPAN><SPAN class="punctuation token">,<\/SPAN>
<SPAN class="string token">"STREET"<\/SPAN><SPAN class="punctuation token">,<\/SPAN><SPAN class="string token">"50 feet "<\/SPAN><SPAN class="punctuation token">,<\/SPAN>
unknown<SPAN class="punctuation token">)<\/SPAN>
<SPAN class="operator token">+<\/SPAN> <SPAN class="string token">"en de wegvoorzijde is "<\/SPAN> <SPAN class="operator token">+<\/span>
<span class="token function">Decode</span><span class="punctuation token">(</span>$feature<span class="punctuation token">.</span>FUNCTCLASS<span class="punctuation token">,</span>
<span class="string token">"FREEWAY"</span><span class="punctuation token">,</span><span class="string token">"1320 feet."</span><span class="punctuation token">,</span>
<span class="string token">"PRINCIPAL ARTERIAL"</span><span class="punctuation token">,</span><span class="string token">"1320 feet."</span><span class="punctuation token">,</span>
<span class="string token">"MINOR ARTERIAL"</span><span class="punctuation token">,</span><span class="string token">"500 tot 660 feet."</span><span class="punctuation token">,</span>
<span class="string token">"MAJOR COLLECTOR"</span><span class="punctuation token">,</span><span class="string token">"500 tot 660 feet."</span><span class="punctuation token">,</span>
<span class="string token">"MINOR COLLECTOR"</span><span class="punctuation token">,</span><span class="string token">"330 feet."</span><span class="punctuation token">,</span>
<span class="string token">"STREET"</span><span class="punctuation token">,</span><span class="string token">"250 feet."</span><span class="punctuation token">,</span>
unknown<span class="punctuation token"> )</span>
De syntax wordt geverifieerd wanneer ik het test:
Maar ik krijg het niet te zien in de daadwerkelijke pop-up. Ik heb geprobeerd om Weergave te gebruiken door "Een beschrijving uit één veld" te selecteren en de expressie uit de keuzelijst te kiezen; ik heb ook geprobeerd "Een aangepaste attribuutweergave" met een verwijzing naar de expressie. Hoe dan ook verschijnt de zin die in het Waarde-gedeelte van de test hierboven wordt getoond niet in de pop-up. Wanneer ik terugga naar de pop-up instellingen, zijn de opties teruggezet naar "Een beschrijving uit één veld" en mijn expressie staat nog steeds opgeslagen in het gedeelte Attribuutexpressies.
Ik dacht dat dit misschien een bug was in 10.6.1 en ik vond en installeerde patch ArcGIS-1061-PFA-SEC2019U1-Patch, maar dat loste het probleem niet op. Ik probeerde ook dezelfde expressie in ArcGIS Online te plaatsen, maar kreeg hetzelfde resultaat.
Misschien wordt Decode niet ondersteund voor pop-ups in 10.6.1? Ik heb de version matrix gecontroleerd, maar ik ben niet zeker of ik de tabel correct lees.
