desc = arcpy.Describe(lyr) if not desc.FIDSet == '': print 'Layer has a selection'
Layer Describe properties has an FIDSet property which returns a semicolon-delimited string of selected feature IDs. If the string is empty no features are selected: desc = arcpy.Describe(lyr) if not desc.FIDSet == '': print 'Layer has a selection'
I would think that you could get an initial count and assign as say numRecords then run a selection and set another get count as selRecords. then check if the selected count is null
arcpy.SelectLayerByAttribute_management(layer.name,"ADD_TO_SELECTION",'"OBJECTID" = 1000000000000') featurecount = int(arcpy.GetCount_management(layer.name).getOutput(0)) if featurecount > 0: #Do Something else: arcpy.SelectLayerByAttribute_management(layer.name, "CLEAR_SELECTION")
Yes, there are many ways to do this, here is one: result = int(arcpy.GetCount_management(Parcels).getOutput(0)) if result: # do something else: print 'No selected features'
Hi,I trying to create an arcpy script that will run only if there are selected features in a layer, however I can't figure out how to get arcpy to test for selected features.I've read posts about using GetCount, however this seems to only work if there is a difference in the number of selected features to the full feature count of the layer. I want my script to run even if EVERY feature in the layer is selected (but ONLY if features are selected).Is there a way I can do this?Cheers,Mike.
