<?xml version="1.0" encoding="utf-8"?> <viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" xmlns:viewer="com.esri.viewer.*" > <fx:Script> <![CDATA[ private function AddXY():void { var myMapPoint:MapPoint = new MapPoint(Number(longText.text),Number(latText.text),map.spatialReference) var myFeatureSet:FeatureSet = new FeatureSet([{geometry:myMapPoint}]); myFeatureSet.geometryType = "esriGeometryPoint"; var params:Object = { "Point_Input": myFeatureSet, //this assumes your gp service is expecting an input called Point_Input }; gp.execute(params); } ]]> </fx:Script> <fx:Declarations> <esri:Geoprocessor id="gp" url="your gp URL" useAMF="false" executeComplete="some event " outSpatialReference="{map.spatialReference}" fault="some event " /> </fx:Declarations> <viewer:WidgetTemplate id="wTemplate"> <s:HGroup width="100%" horizontalAlign="left" verticalAlign="middle"> <s:Label width="60" id="latLabel" text="Latitude:" /> <s:TextInput width="100" maxChars="9" id="latText" restrict="0-9\." /> <s:Label width="60" id="longLabel" text="Longitude:" /> <s:TextInput width="100" maxChars="9" id="longText" restrict="0-9\." /> <s:Button width="100" label="Add XY" click="AddXY()" /> </s:HGroup> </viewer:WidgetTemplate> </viewer:BaseWidget>
...in the documentation it lists "recordset" as a valid input parameter type in the tag documentation, but in the geoprocessing widget documentation it states: ... "RecordSet types are not supported as input parameters."
