import arcpy, os from arcpy import env folder1 = r"C:\temp\python\A" folder2 = r"C:\temp\python\B" env.workspace = folder1 for file in arcpy.ListFiles("*.csv"): fileName = file.split(".")[0] env.workspace = folder2 for file2 in arcpy.ListFiles("*.csv"): if fileName in file2: arcpy.FileCompare_management(folder1 + os.sep + file, file2, "ASCII", "CONTINUE_COMPARE", r"C:\Temp\Python" + os.sep + fileName + "_compare.txt") env.workspace = folder1
I tried to use this script and it seems that everything is working. Thank You. I have one question more why in this script "fileName = file.split(".")[0]" exist "[0]. What is changing by this?Maybe it is not smart question, but as I mentioned I just started in python.
>>> "filename.txt".split(".") ['filename', 'txt'] >>> "filename.txt".split(".")[0] 'filename'
>>> "file.name.txt".split(".") ['file', 'name', 'txt'] >>> os.path.splitext("filename.txt") ('filename', '.txt') >>> os.path.splitext("file.name.txt") ('file.name', '.txt')
import arcpy, os from arcpy import env folder1 = r"C:\temp\python\A" folder2 = r"C:\temp\python\B" env.workspace = folder1 for file in arcpy.ListFiles("*.csv"): # calculate file name # "file_name.csv" -> "file_name_A.csv" rootname = os.path.splitext(file)[0] file2name = "{0}_A.csv".format(rootname) file2path = os.path.join(folder2, file2name) # calculate compare file (output) file name compare_results = "{0}_cmp.txt".format(os.path.basename(file)) # compare the files arcpy.FileCompare_management(file, file2path, "ASCII", "CONTINUE_COMPARE", compare_results)
