Is there a way to have my 3D point symbols (primitive: "cube" in this case) highlighted in some way when I click them for a popup in the 3D SceneView?
OK, thanks so much Raluca. He is the code that worked for me. Code from David Coley at this post https://community.esri.com/message/636169-jsapi-40-popup-set-highlight-graphic-on-feature-layer-click?q=4%20highlight%20cli… helped as well.
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//hitTest used to create a selection graphic for the popup</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitTest</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>screenPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//screenPoint</SPAN> <SPAN class="keyword token">var</SPAN> resultGraphic <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> symbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">PointSymbol3D</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> symbolLayers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ObjectSymbol3DLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">400</SPAN><SPAN class="punctuation token">,</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">400</SPAN><SPAN class="punctuation token">,</SPAN> anchor<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"bottom"</SPAN><SPAN class="punctuation token">,</SPAN> resource<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> primitive<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"cube"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> material<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">85</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.5</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeAll</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>resultGraphic<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> selectionGraphic <SPAN class="operator token">=</SPAN> resultGraphic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clone</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> selectionGraphic<SPAN class="punctuation token">.</SPAN>symbol <SPAN class="operator token">=</SPAN> symbol<SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>selectionGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi David,
Not yet, that's a long-awaited feature and we are currently working on it.
Depends on your use case, but for cube symbols you could imitate that behaviour by cloning the graphic when the user clicks on it and changing the color & size. You can get the clicked graphic using view.hitTest(). Then you add the new graphic to the view.graphics. That way it will look like the graphic is selected:
