I have the below code that is returning a popup window via a map click.Β The data I have is getting to large for a popup and want to move this to an HTML DIV in a side window.Β
Anyone have any examples of how to push this to an html div tag instead of a popup?
<SPAN class="keyword token">var</SPAN> infoTemplateHazmat <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
infoTemplateHazmat<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setTitle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Hazmat Incidents"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
infoTemplateHazmat<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setContent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"<table>"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"<tr><td>Status</td><td>${status}</td></tr>"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"<tr><td>Datetime</td><td><i>${UTC_DATETIME}</i></td></tr>"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"</table><hr>"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> hazmat <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Farcgis.vdem.virginia.gov%2FArcGIS%2Frest%2Fservices%2FTraffic%2FVATraffic_IncidentPoints%2FMapServer%2F4" target="_blank">https://arcgis.vdem.virginia.gov/ArcGIS/rest/services/Traffic/VATraffic_IncidentPoints/MapServer/4</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
mode<SPAN class="punctuation token">:</SPAN> FeatureLayer<SPAN class="punctuation token">.</SPAN>MODE_ONDEMAND<SPAN class="punctuation token">,</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> infoTemplateHazmat
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
legendLayers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> layer<SPAN class="punctuation token">:</SPAN> hazmat<SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Hazmat Incidents'</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>βββββββββββββ<SPAN class="line-numbers-rows"><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN><SPAN>β</SPAN></SPAN>
