I have a bit of code that toggles the icon of an Addin button:
| isChecked = Not isChecked |
| Dim pUID As New UIDClass |
| pUID.Value = My.ThisAddIn.IDs.FloorCBX |
| Dim pCI As ICommandItem |
| Dim bm As Bitmap |
| pCI = My.ArcMap.Application.Document.CommandBars.Find(pUID, True, True) |
| If isChecked Then |
| | bm = New Bitmap("E:\customnet\spacedemo\Images\FloorCBX2.png") |
| Else |
| | bm = New Bitmap("E:\customnet\spacedemo\Images\FloorCBX.png") |
| End If |
| 'Dim bm As New Bitmap("E:\customnet\spacedemo\Images\FloorCBX2.png") |
| pCI.FaceID = ESRI.ArcGIS.ADF.COMSupport.OLE.GetIPictureDispFromBitmap(bm) |
While this works on my development machine, it obviously won't elsewhere due to the hard-coded image file paths. I have seen in the "Build Action" of the image that I can set it to "AddInContent", but I have not found any info on how to reference that embedded bitmap in my code. So, how do I modify my code to get the bitmap from the Addin's content instead of a file?
