Added your method to the code behind for a simple button Add-In. Added the appropriate references, for example IMap is an interface that comes from an ESRI provided assembly (ESRI.ArcGIS.Carto.dll):IMap (from ESRI Carto)Added the following references through Project > Add Reference in Visual Studio:ESRI.ArcGIS.CartoESRI.ArcGIS.GeodatabaseESRI.ArcGIS.DisplayNow on the buttons click we want to call this method passing in the appropriate arguments. With Add-ins we have access to a static class called ArcMap. This will represent our initial entry point as with 'ThisDocument', for example, with VBA. Here is an example of calling the method: protected override void OnClick() { ConvertLabelsToAnnotationSingleLayerMapAnno(ArcMap.Document.FocusMap, 0); .... The code will pass the Active map (dataframe) and the value of 0 to your method. This tells it to process on the first layer in the given map. The labels are sucessfully converted to Map annotation in a new annotation group.
using System; using System.Collections.Generic; using System.Text; using System.IO; using ESRI.ArcGIS.Carto; using ESRI.ArcGIS.Geodatabase; using ESRI.ArcGIS.Display; using ESRI.ArcGIS.esriSystem; namespace ArcMapAddin2 { public class LabelToAnno : ESRI.ArcGIS.Desktop.AddIns.Button { public LabelToAnno() { } protected override void OnClick() { // // TODO: Sample code showing how to access button host // ConvertLabelsToAnnotationSingleLayerMapAnno(ArcMap.Document.FocusMap, 0); ArcMap.Application.CurrentTool = null; } protected override void OnUpdate() { Enabled = ArcMap.Application != null; } static void ConvertLabelsToAnnotationSingleLayerMapAnno(IMap pMap, int layerIndex) { IConvertLabelsToAnnotation pConvertLabelsToAnnotation = new ConvertLabelsToAnnotationClass(); ITrackCancel pTrackCancel = new CancelTrackerClass(); //Change global level options for the conversion by sending in different parameters to the next line. pConvertLabelsToAnnotation.Initialize(pMap, esriAnnotationStorageType.esriMapAnnotation, esriLabelWhichFeatures.esriVisibleFeatures, true, pTrackCancel, null); ILayer pLayer = pMap.get_Layer(layerIndex); IGeoFeatureLayer pGeoFeatureLayer = pLayer as IGeoFeatureLayer; if (pGeoFeatureLayer != null) { IFeatureClass pFeatureClass = pGeoFeatureLayer.FeatureClass; //Add the layer information to the converter object. Specify the parameters of the output annotation feature class here as well. pConvertLabelsToAnnotation.AddFeatureLayer(pGeoFeatureLayer, pGeoFeatureLayer.Name + "_Anno", null, null, false, false, false, false, false, ""); //Do the conversion. pConvertLabelsToAnnotation.ConvertLabels(); //Turn off labeling for the layer converted. pGeoFeatureLayer.DisplayAnnotation = false; //Refresh the map to update the display. IActiveView pActiveView = pMap as IActiveView; pActiveView.Refresh(); } } } }
static void ConvertLabelsToAnnotationSingleLayerMapAnno(IMap pMap, int layerIndex){ IConvertLabelsToAnnotation pConvertLabelsToAnnotation = new ConvertLabelsToAnnotationClass(); ITrackCancel pTrackCancel = new CancelTrackerClass(); //Change global level options for the conversion by sending in different parameters to the next line. pConvertLabelsToAnnotation.Initialize(pMap, esriAnnotationStorageType.esriMapAnnotation, esriLabelWhichFeatures.esriVisibleFeatures, true, pTrackCancel, null); ILayer pLayer = pMap.get_Layer(layerIndex); IGeoFeatureLayer pGeoFeatureLayer = pLayer as IGeoFeatureLayer; if (pGeoFeatureLayer != null) { IFeatureClass pFeatureClass = pGeoFeatureLayer.FeatureClass; //Add the layer information to the converter object. Specify the parameters of the output annotation feature class here as well. pConvertLabelsToAnnotation.AddFeatureLayer(pGeoFeatureLayer, pGeoFeatureLayer.Name + "_Anno", null, null, false, false, false, false, false, ""); //Do the conversion. pConvertLabelsToAnnotation.ConvertLabels(); //Turn off labeling for the layer converted. pGeoFeatureLayer.DisplayAnnotation = false; //Refresh the map to update the display. IActiveView pActiveView = pMap as IActiveView; pActiveView.Refresh(); }}
