map.disableClickRecenter(); map.disableDoubleClickZoom();
//Measure button click handler. function MeasureBtnClickHandler() { doIdentify = false; if (dijit.byId('dFloatingPane02').open==false) { createMeasure(); this.navToolbar.deactivate(); //I am calling this method as you mentioned } } //CreateMeasure function function createMeasure() { measurement = new esri.dijit.Measurement({ map: map }, dojo.create('measure')); dojo.place(measurement.domNode,dojo.byId('measurementDiv')); measurement.startup(); dijit.byId('dFloatingPane02').show(); dijit.byId('dijit_DialogUnderlay_0').hide(); }
function tglMeasurementOff() { measurement.destroy(); dijit.byId('dFloatingPane02').hide(); //map.enableMapNavigation()(); }
//When any navigation tool is clicked, following method is called. function DeactivateMeasure() { measurement.setTool("location",false); measurement.setTool("area",false); measurement.setTool("distance",false); }
//Measure button click handler. function MeasureBtnClickHandler() { doIdentify = false; if (dijit.byId('dFloatingPane02').open==false) { createMeasure(); this.navToolbar.deactivate(); //I am calling this method as you mentioned } } ...<snip>... Just calling navToolbar.deactivate() was doing nothing.So, I am calling disable methods on map (as mentioned in my earlier post).
measure.clearResult(); if(measure.activeTool){ measure.setTool(measure.activeTool, false); }
Thanks Jian for the reply.I had already tried to implment what you are suggesting that but that click event was getting fired randomly.I did not have much control on it.Anyways, I created my own control by giving calls to the Geometry service.It is not as fine as Measurement Widget, but I have full control on it and it does what I asks it to do.:)Thanks.
