<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Map Extent and Mouse Coordinates" creationComplete="combobox()"> <fx:Script> <![CDATA[ import mx.collections.ArrayCollection; private function combobox():void { var comboArray:ArrayCollection = new ArrayCollection(); comboArray = comm_layer.layerInfos.Communities_Places //the specific layer in the map service cmb.dataProvider = comboArray; cmb.labelField = comboArray.comm_name_ //field within the Communities_Places layer } ]]> </fx:Script> <s:layout> <s:VerticalLayout paddingTop="6"/> </s:layout> <s:HGroup> <s:ComboBox id="cmb" right="250"/> </s:HGroup> <esri:Map id="myMap"> <esri:extent> <esri:Extent xmin="-13338986.2116637" ymin="3926661.77417242" xmax="-13002755.460699" ymax="4152028.76378653"> <esri:SpatialReference wkid="3857"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer id="comm_layer" url="http://10.2.8.73/ArcGIS/rest/services/ZNET_Public/city_maskForExtent/MapServer"/> </esri:Map> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.events.MapEvent; import com.esri.ags.events.QueryEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.tasks.supportClasses.Query; import mx.collections.ArrayList; import spark.events.IndexChangeEvent; protected function map_loadHandler(event:MapEvent):void { var query:Query = new Query(); query.outFields = [ "STATE_NAME" ]; query.outSpatialReference = map.spatialReference; query.returnGeometry = true; query.where = "1=1"; queryTask.execute(query); } protected function queryTask_executeCompleteHandler(event:QueryEvent):void { ddList.dataProvider = new ArrayList(event.featureSet.features); } protected function ddListLabelFunction(item:Graphic):String { return item.attributes["STATE_NAME"]; } protected function ddList_changeHandler(event:IndexChangeEvent):void { var stateExtent:Extent = Graphic(ddList.selectedItem).geometry.extent; map.extent = stateExtent // make sure the whole extent is visible if (!map.extent.contains(stateExtent)) { map.level--; } } ]]> </fx:Script> <fx:Declarations> <esri:QueryTask id="queryTask" executeComplete="queryTask_executeCompleteHandler(event)" showBusyCursor="true" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5" useAMF="false"/> </fx:Declarations> <s:controlBarContent> <s:DropDownList id="ddList" width="200" change="ddList_changeHandler(event)" labelFunction="ddListLabelFunction" prompt="Choose a state to zoom to"/> </s:controlBarContent> <esri:Map id="map" load="map_loadHandler(event)"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> </esri:Map> </s:Application>
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Map Extent and Mouse Coordinates" creationComplete="combobox()"> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.QueryEvent; import com.esri.ags.tasks.QueryTask; import com.esri.ags.tasks.supportClasses.Query; import com.esri.ags.utils.GraphicUtil; import mx.collections.ArrayCollection; private function combobox():void { var comboQueryTask:QueryTask = new QueryTask(); comboQueryTask.url = "http://10.2.8.73/ArcGIS/rest/services/ZNET_Public/city_mask/MapServer/0"; comboQueryTask.useAMF = false; var comboQuery:Query = new Query(); comboQuery.returnGeometry = true; comboQuery.where = "1=1"; comboQuery.outFields = ["CITY_COMM_"]; comboQuery.outSpatialReference = myMap.spatialReference; comboQueryTask.execute(comboQuery); comboQueryTask.addEventListener(QueryEvent.EXECUTE_COMPLETE, onQueryComplete); } private var commExtent:Extent = new Extent(); private function onQueryComplete(event:QueryEvent):void { var featureSet:FeatureSet = event.featureSet; var results:ArrayCollection = new ArrayCollection(); for each (var graphic:Graphic in featureSet.features) { var fieldValue:String = graphic.attributes["CITY_COMM_"].toString(); results.addItem({label: fieldValue, data: graphic}); } cmb.labelField = "label"; cmb.dataProvider = results; var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(featureSet.features); commExtent = graphicsExtent; } private function change():void { var extent2:Extent = Graphic(cmb.selectedItem).geometry.extent; myMap.extent = extent2; } ]]> </fx:Script> <s:layout> <s:VerticalLayout paddingTop="6"/> </s:layout> <s:HGroup> <s:ComboBox id="cmb" right="250" change="change()" width="350" selectedItem="{{label:'Select Your Community'}}"/> </s:HGroup> <esri:Map id="myMap"> <esri:extent> <esri:Extent xmin="-13338986.2116637" ymin="3926661.77417242" xmax="-13002755.460699" ymax="4152028.76378653"> <esri:SpatialReference wkid="3857"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer id="comm_layer" url="http://10.2.8.73/ArcGIS/rest/services/ZNET_Public/city_maskForExtent/MapServer"/> </esri:Map> </s:Application>
<layer> <layerurl>http://gis.rksk.dk/ArcGIS/rest/services/AdresseLokalplan/MapServer/0</layerurl> <layeroutfield>ADR_NR_POST</layeroutfield> <layerzoomscale>1500</layerzoomscale> </layer>
var lyrList:XMLList = configXML..layer; for (var i:int = 0; i < lyrList.length(); i++) { layerURL = lyrList.layerurl; layerOutField = lyrList.layeroutfield; layerZoomScale = lyrList.layerzoomscale; var comboQueryTask:QueryTask = new QueryTask(); comboQueryTask.url = layerURL; comboQueryTask.useAMF = false; var comboQuery:Query = new Query(); comboQuery.returnGeometry = true; comboQuery.where = "1=1"; comboQuery.outFields = [layerOutField]; comboQuery.outSpatialReference = map.spatialReference; comboQueryTask.execute(comboQuery); comboQueryTask.addEventListener(QueryEvent.EXECUTE_COMPLETE, onQueryComplete); } private function onQueryComplete(event:QueryEvent):void { var featureSet:FeatureSet = event.featureSet; for each (var graphic:Graphic in featureSet.features) { var fieldValue:String = graphic.attributes[layerOutField].toString(); results.addItem({label: fieldValue, data: graphic}); } var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(featureSet.features); commExtent = graphicsExtent; }
Dasa,I used the code you posted with a point layer. I get weird results with the zoom... does the code work for a point layer or just for a polygon layer?june
