Hello, I will admit, I am a bit green when it comes to ArcGIS for Server and ArcSDE, but I have gone through all the documentation I could find, and blogs from non-Esri sources, and cannot find an answer for 10.1 that works, and it may be that I am missing a step along the way.What I need: To be able to add the ArcServer/SDE instance from AWS to ArcGIS for Desktop on my local machine via "Add Databse Server" and/or "Add Database Connection".What I have:ArcGIS Server 10.1 and ArcSDE (SQL Server) on Amazon Web ServicesI am able to connect to to the ArcGIS Server via the "Add ArcGIS Server" method.What I have tried:Everything I could think of.I can connect to the SDE fine on the AWS machine.Add Database Server - I tried <IP address>\MSSQLSERVER and <IP address>\sqlexpressAdd Database Connection - Platform - SQL ServerAdd Database - Instance - I have tried variations of the server url and the ip address and the dynamic dnsAdd Database - Authentication - I've tried to, but I think i need to use "database" and have entered the Administrator info here.I never get a list of databases (should be EGDB and geodata).Any help would be greatly appreciated!
I assume you are hitting public ip and not internal aws ip right? Also, do you have sql ports open for external use in aws security console?
