I've setup some group widgets in my WAB DE 2.12 app config file. Although the functionality works, I'm receiving an error in the console. This only happens when I configure the "groupSetting" in the header controller config to use type: "dropdown". Is this a bug?
js.arcgis.com/3.28/init.js:115 TypeError: Cannot read property 'className' of null at Object.add [as addClass] (js.arcgis.com/3.28/init.js:216) at Object. (themes/FoldableTheme/widgets/HeaderController/Widget.js?wab_dv=2.12:1136) at js.arcgis.com/3.28/init.js:64 at l (js.arcgis.com/3.28/init.js:108) at e.then.b.then (js.arcgis.com/3.28/init.js:111) at Object._showIconContent (themes/FoldableTheme/widgets/HeaderController/Widget.js?wab_dv=2.12:1133) at Object. (themes/FoldableTheme/widgets/HeaderController/Widget.js?wab_dv=2.12:1023) at js.arcgis.com/3.28/init.js:64 at l (js.arcgis.com/3.28/init.js:108) at k (js.arcgis.com/3.28/init.js:108) "TypeError: Cannot read property 'className' of null at Object.add [as addClass] (https://js.arcgis.com/3.28/init.js:216:220)
