Thanks, that's good to know..
Just to clarify I need to change the source code of the flex application itself correct?
I tried following the path you outlined above but couldn't find the same folder paths on my machine..
I'm looking under the 'ArcGIS Viewer for Flex' install folder. Does it sound like I'm in the correct spot?
Sam,
The same still applies.
Is the method described above still the only way to disable the "description" pick list option under the Layers button? This is an older post, but I'm not finding many recent content on this in the forums.
I'm using flex 3.6 build date 12.13.2013.
Thanks for any insight!
Sam
Matt, There is nothing configurable for this. You would have to change the code in /FlexViewer2.5/src/com/esri/viewer/components/toc/tocClasses/TocLayerMenu.mxml in the descriptionOrDownloadLabel_clickHandler function.
