import arcpy polygonZ = r"C:\tmp\Testing.gdb\PolygonZ" rows = arcpy.SearchCursor(polygonZ) for row in rows: feature = row.SHAPE #get the geometry into variable partNum = 0 partCount = feature.partCount sumZ = 0.0 totalPntCount = 0 #feature can have multiple parts - first goes iteration through parts while partNum < partCount: part = feature.getPart(partNum) #the output is Array of points pnt = part.next() #take first point from Array of points pntNum = 0 pntCount = part.count #iterate through points (first point is doubled as last point - last point is excludec) while pntNum < (pntCount - 1): valueZ = pnt.Z sumZ += valueZ pnt = part.next() pntNum += 1 totalPntCount += 1 partNum += 1 meanZ = sumZ/totalPntCount print meanZ del rows, row
import arcpy, csv, os, sys, traceback from arcpy import env arcpy.env.overwriteOutput = True ##try: #track segment FC segZ = "C:/Documents and Settings/h6e6v/My Documents/Leader_Work/PTC_DATA/Test/MissingZTest_1.gdb/segs_noZvalue_test" pntZ = "C:/Documents and Settings/h6e6v/My Documents/Leader_Work/PTC_DATA/Test/MissingZTest_1.gdb/pnts_withZvalue_test" descs = arcpy.Describe(segZ) shapefieldnames = descs.ShapeFieldName descp = arcpy.Describe(pntZ) shapefieldnamep = descp.ShapeFieldName newPoint = arcpy.Point() segUC = arcpy.UpdateCursor(segZ) for seg in segUC: bXYZ = seg.getValue(shapefieldnames) partNum = 0 for part in bXYZ: part_list = [] for item in bXYZ.getPart(partNum): if item: x = str(item.X) ix = x[:14] y = str(item.Y) iy = y[:14] pnts = arcpy.UpdateCursor(pntZ) iz = item.Z for pnt in pnts: pXYZ = pnt.getValue(shapefieldnamep) point = pXYZ.labelPoint pointX = point.X pointY = point.Y pointZ = point.Z if ix == str(pointX): if iy == str(pointY): print item.ID print ix+" = "+str(pointX) print iy+" = "+str(pointY) print item.Z print str(pointZ) else: pass else: pass else: pass
