Hi Ian,
I am trying to make sure that I have everything correctly here. Are you saying that using the Runtime you are seeing that when the symbols completely overlap, you don't cannot see the fill of the top feature and nothing from the bottom feature? In case of a partial overlap, you see the same problem only in the overlapping section.
Can you please provide some screenshots of what you are are seeing? Also, which version of the SDK are you using eg 100.1/10.2.6? And API did you use for rendering? QML, C++ and if C++, Widgets or Quick?
Koushik
