import arcpy mxd=arcpy.mapping.MapDocument("C:\\Path\\To\\Your\\Map.mxd") #path to your MXD targetLayers=["Alberta","Ontario","Nova Scotia"] #Layer names as they appear in TOC df=arcpy.mapping.ListDataFrames(mxd)[0] #if you are not using the first dataframe in the MXD, change '0' to the 0-based index of whichever dataframe use wish to use allLayers=arcpy.mapping.ListLayers(df) for targetLayer in targetLayers: for lyr in allLayers: if targetLayer==lyr.name: #Zoom to layer: ext=lyr.getExtent() df.extent=ext #Export TIF: arcpy.mapping.ExportToTIFF(mxd, "C:\\Path\\To\\TIFs\\"+targetLayer+".tif") #path to desired location and filename of TIF file del mxd del allLayers del lyr #this line will error if you supply an empty MXD print "Completed Successfully!"
