Hi there,
when I build my adobe flash builder project, I get the errors as shown in the picture attached, but I still can run the web application with a strange display.
Is there anything missed in my project?
Hi Robert,
After I deleting the project and importing the original one again, the errors disappear.
Thank you very much!
I use Adobe Flex SDK 4.6. It is strange that yesterday no these errors.
Li Yao,
What version of the Adobe Flex SDK are you using. The ArcGIS Viewer for Flex has a minimum requirement of Adobe Flex SDK 4.6
Thanks for the quick reply. Yes I have src/com/esri/viewer/skins/HScrollBarSkin.mxml in my project. The HScrollBarSkin.mxml code:
<?xml version="1.0" encoding="utf-8"?>
// Copyright (c) 2010-2011 Esri. All Rights Reserved.
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
@private
<s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
alpha.disabled="0.5"
alpha.inactive="0.5"
minHeight="15"
minWidth="35">
<fx:Metadata>
[HostComponent("spark.components.HScrollBar")]
</fx:Metadata>
<s:states>
<s:State name="normal"/>
<s:State name="disabled"/>
<s:State name="inactive"/>
</s:states>
<s:Button id="track"
width="54"
left="16" right="15"
focusEnabled="false"
skinClass="com.esri.viewer.skins.HScrollBarTrackSkin"/>
<s:Button id="thumb"
skinClass="com.esri.viewer.skins.HScrollBarThumbSkin"
visible.inactive="false"/>
<s:Button id="decrementButton"
left="0"
enabled.inactive="false"
skinClass="com.esri.viewer.skins.ScrollBarLeftButtonSkin"/>
<s:Button id="incrementButton"
right="0"
skinClass="com.esri.viewer.skins.ScrollBarRightButtonSkin"/>
</s:SparkSkin>
Do you have "src/com/esri/viewer/skins/HScrollBarSkin.mxml" in your project?
