So when I worked on my 1938 historical aerial photo tracking map, what this means is whenever I worked on orthorecification from Agisoft PhotoScan/MetaShape I worked on and I had to add a new orthos to the Tracking map each time I am done with it. Before I start to work on this in ArcGIS Pro , I import the mxd from ArcMap 10.5.1 to ArcGIS Pro 2.3.2.
As I was working on to make some change or fix or add in Pro, I copied all of the layers from a Map frame in the Layout to the new Map tab and make some change to the symbology I worked on.
Now my question to you or anyone who have worked in Pro, How do I update the Map Frame in the Layout to reflect the change the symbology from the Map tab ? It would be a nice if the Layout has a Update from the Map Frame I worked on but I don't see any around..
What I did was to copy the layer from Map tab to the Layout tab and had to update the symbology for one of the layer
If need to clarify can contact me at 719-281-2119 or email me here : psiccgis81008@gmail.com
I am in the office from 8:00 to 4:30 pm Mountain Time. M-F
