I have a simple ascii csv file that contains lat lon data in decimal degrees. I have added the table to my ArcMap project. How do I generate a point feature class that I can display on my map?
as suspected... it isn't an "ascii" file but contains ascii data.
Often referred to as a "event layer" or simply "csv" for comma,separated values to identify it from tab or space delimited
Add XY Coordinates—Help | ArcGIS for Desktop
ascii csv has different meanings unfortunately to some people.
It if is truly an ascii file ASCII to Raster—Help | ArcGIS for Desktop
then followed by Raster to Point—Help | ArcGIS for Desktop
There are other solutions involving other arcmap tools and/or python solutions, but if the above isn't describing the correct format, then you will have to clarify.
Dan,
The file is a very simple comma delimited text file (.csv) with data in columnar format with headers. The data includes a column for latitude and longitude and I have added the file to my ArcMap project and is now a table. How do I display this as points on my map?
Chris
Make x,y event layers would be the tool for that. Then export the event layer to a feature class by right clicking in the TOC then data then Data Export.
You can also right click on csv table in the TOC and there is an option for make x,y events.
And to emphasis both my point and Knudsen's point... regardless how you make the initial layer, you need to:
