<userControls:DraggableWindow x:Name="DragWondow" Visibility="{Binding ElementName=Map, Path=Layers[SpatialQueryGraphicsLayer].Graphics.Count, Converter={StaticResource NumOfSelectToVisibilityConverter}}" Width="280" Height="180" Foreground="Black" IsOpen="{Binding Visible, Mode=TwoWay}" Grid.Row="2" > <esri:FeatureDataGrid Visibility="{Binding ElementName=Map, Path=Layers[SpatialQueryGraphicsLayer].Graphics.Count, Converter={StaticResource NumOfSelectToVisibilityConverter}}" Grid.Row="2" Grid.Column="1" x:Name="MyDataGrid" Map="{Binding ElementName=Map}" GraphicsLayer="{Binding ElementName=Map, Path=Layers[SpatialQueryGraphicsLayer]}" /> </userControls:DraggableWindow>
Hi Joe,1. I've decided to give up on preserving the last tool meanwhile so, at the moment, I don't need the QueryComplete event at the end. I do need to check, whether the Url of the active layer is equal to X or equal to None and if the answer is yes, do not execute the spatialQueryAction. Is that possible without writing my own spatialQuery?2. Please send me the sample of a FeatureDataGrid and FeatureDataForm integrated into a DraggableWindow.I hope I don't nagg too much...So many thanks,Miri
Hi Joe,1. Now it is finally works. I wasn't aware of all these DataContext issues....I'm studing and programming at the same time so I miss things. I haven't tried the symbol yet but I'm sure it will work. Thanks a lot!
2. So sweet of you to write this code on action completion. The thing is that if there is so much code for it, I don't see the advantage of using it instead of QueryTask. Can you see any advantage?
3. How do you know what is: Toda Raba?
4. Do you have a tip/sample for wrapping DataGrid (or featureDataGrid) in a draggable/floatingWindow with close button? I saw some threads about it in the forum but couldn't find someting that attracted me.
<Button x:Name="QueryButton" Height="30" Width="30" Margin="0,0,2,0" HorizontalContentAlignment="Left" Padding="2" Content="Query"> <i:Interaction.Triggers> <i:EventTrigger EventName="Click"> <Actions:SpatialQueryAction DrawMode="Rectangle" OutFields="FID,STATE_NAME,STATE_ABBR" LayerID="MyQueryResultsGraphicsLayer" Url="{Binding ElementName=QueryButton, Path=DataContext.Url}" Symbol="{StaticResource GraphicsLayerFillSymbol}" QueryComplete="SpatialQueryAction_QueryComplete" TargetName="Map" /> </i:EventTrigger> </i:Interaction.Triggers> </Button>
public MainPage() { InitializeComponent(); ActiveLayer = new ActiveLayer { Url = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/2" }; QueryButton.DataContext = ActiveLayer; } public ActiveLayer ActiveLayer { get; set; } private void SpatialQueryAction_QueryComplete(object sender, EventArgs e) { }
I admire your patience....Thanks,Miri
<actions:SetLayerUrlAction Url="{Binding _ActiveLayer.URL}"/>
public MainPage() { InitializeComponent(); DataContext = this; }
<actions:SetLayerUrlAction Url="{Binding ActiveLayer.URL}"/>
public MainPage() { InitializeComponent(); ActiveLayer = new ActiveLayer(); DataContext = ActiveLayer ; } public ActiveLayer ActiveLayer { get; set; } <actions:SetLayerUrlAction Url="{Binding URL}"/>
Symbol="{Binding _activeLayer.Symbol}"
Hi,Is there a way to show a DataGrid of the selected features using SpatialQueryAction.There is a sample called: http://resourcesbeta.arcgis.com/en/help/silverlight-api/samples/start.htm#GraphicsActionsI want to extend this sample to show also the dataGrid of the selection's result.Thanks a lot,Miri
<esri:FeatureDataGrid Grid.Row="2" x:Name="MyDataGrid" Map="{Binding ElementName=MyMap}" GraphicsLayer="{Binding ElementName=MyMap, Path=Layers[LayerIDPassedToAction]}" />
