Does the server have enough disk space for the specified export and/or import directory in order to accommodate the output?Is the directory of the file geodatabase specified as a network share or a mapped drive letter to a networked location? In other words, from your local PC are you specifying a network share location or drive letter to a mapped network shared location which points to the server?
Within the past month, I've started experiencing problems with exporting data from either an mxd or another gdb, to a gdb. Or, importing shapefiles to a gdb. I get an error like:"Error exporting data.The item was not found. [ItemType:{70737809-852C4A03-9E22-2CECEA5B9BFA}]The table was not found. [feature class name] <- "feature class name" is of course the name of any feature class I try and export.This started shortly before Christmas, I've not had any problems before that. As I mentioned, I cannot even import shapefiles into thegdb, I can export files out of the gdb as a .shp or even export from the mxd to a .shp but no into a gdb.Currenty, I am using Win7 with ArcGis 10.0.
