I didn't mean to suggest that Jamal wasn't trying; instead I was suggesting that no amount of effort can make some data right, and that under certain conditions trying harder wouldn't necessarily improve the situation. "Repair" is all well andgood, but it can't anticipate every data condition. Some data is intrinsically incapable of correction; when you encounter some you need to be ready toknow when to give up.
Although I basically agree with most of what you write (which can be exemplified by the well known "garbage in - garbage out"), I don't think it is fair towards Jamal to suggest he isn't doing his best to get this right.
Now, this problem is like a nightmare for me. From now on, I�??ll never load data to the enterprise layer without repairing it.
It is Marco, macros is what you run to fix your data 😉The specific problem of the geometry with "self intersections" as discusses above, can be repaired by Repair Geometry.I don't have an answer for the "donuts/outer shells" issue, nor can probably provide one, but could you potentially post this entire layer, maybe in parts if to big to post in one ZIP, that is causing these issues? You could drop unnecessary attribute fields to reduce the size somewhat. Without that, it is impossible to say more.
Many thanks Vince and Macro for the contribution.
How to solve the issue of �??two donuts or two outer shells overlap�?� in the enterprise geodatabase (SQL, Oracle, etc.)?
Although I basically agree with most of what you write (which can be exemplified by the well known "garbage in - garbage out"), I don't think it is fair towards Jamal to suggest he isn't doing his best to get this right. I have seen my share of data conversion / quality issues in the past 20 years, not likely to be anywhere as broad as your experiences though, but enough to well know that at some point you have to fix things in production itself, and possibly significantly adjust workflows including the introduction of new software like for example AutoCAD Map 3D, to allow more stringent quality control at the data production sites via geometry and topology checks in the native software, instead of by trying to "fix" things afterwards in GIS.That said, considering as I understood it, Jamal needs to work with a range of data producers in his country Palestine (different municipalities and such), I think this task is a very tough one, even for way better positioned countries like the Netherlands and the US (much longer history of GIS / CAD usage, way more budget and expertise: there isn't even a local distributor for ESRI in Palestine if I have to believe the ESRI website...).Here in the Netherlands, they are now going into a huge multi million project in a attempt to build a uniform large scale (1:100-1:1000) object oriented map of the entire country (point, line, polygon). This will require the cooperation of literally hundreds of parties that already maintain the base data (e.g. country, state and municipality level). Data will be stored in one central database. Statistics for this are daunting: expected 100 million(!) geometries, with over 1 billion vertices, with a need to store history as well.Although much focus has been put on automated geometric integrity and topology checks and automated assembly prioritizing high precision data, only the near future will tell what plethora of data conversion and data quality issues they will run into... It is likely to open Pandora's box for some organizations... while others probably fare well.To get back to the real unanswered question: it would still be nice to hear some comments by ESRI as to why the particular geometry is not rejected / auto-fixed. I realize this is a "Technical Support" matter, but my ArcGIS for Home Use license doesn't allow me to start a support call. Jamal may, but is also not in the best position considering no local support in his country.Well, it is probably going to remain unanswered for now...
I think this description mischaracterizes the problem. You have bad data on input, and insufficient processing to correct the errors. The data loss occurred long before it entered the geodatabase. Sometimes you need to code your own algorithms for data recovery, and sometimes data recovery isn't fully possible. In over 25 years as a data conversion specialist, I've run into quite a few sources that were too corrupt to recover, even if we were to spend a million dollars on the effort. At that point, you need a client/manager who isn't willing to send any more good money after bad, no matter how promising the next recovery attempt looks. - V
I hope ESRI experts can provide their inputs in this regard. This issue is critical as it leads to data loss.
Jamal,I now had a more thorough look at the sample data you provided as a File Geodatabase in above post. I can confirm:- That the Feature Class it contains (LanduseAndRoadsPolygons_FME) has an error in the last geometry with OBJECTID 51, as detected by Check Geometry and reported as "self intersections".- Using Copy/Paste to a Desktop Geodatabase in SQL Server 2012 Express doesn't lead to automatic fixing of the geometry in question (contrary to what the Check Geometry Help topic suggests). If I copy the Feature Class back to the FGDB and run Check Geometry again, it is still reported as having self intersections.- Using Import/Export (which uses the Feature Class to Feature Class tool) instead of Copy/Paste gives a similar result: the invalid geometry is happily transferred from the Desktop Geodatabase to the FGDB and back, without any automated fixes applied. So I can't reproduce the "difference" Vince described in this post in the thread.- I can not reproduce the "two donuts or outer shells overlap" issue you described, but since you provided another small test dataset with a detected error, and not the large one that initiated this thread, this is no real surprise.- I also tried to load the data with the erroneous geometry in the Open Source QGIS (2.2.0 Valmiera). QGIS has an option for checking geometries as well. I opened both straight the FGDB Feature Class (which is possible using the Add Vector Layer option and choosing "folder" instead of "file"), and a converted shapefile version of the layer, but QGIS is unable to detect any geometric error in both of these... so it considers them valid (may have to do with the type of validation checks).It starts to look like a bug / loop hole that may need fixing. Sorry to see no one else of ESRI staff responded yet and did some tests with this data, although an official support call is the way to go here.
Back to my issue:Please, consider the attached file geodatabase layer. It has �??self intersections�?� error. Nevertheless, Copy\Paste from file geodatabse to enterprise works fine without fixing the error (repair geometry).[ATTACH=CONFIG]33421[/ATTACH], [ATTACH=CONFIG]33422[/ATTACH], [ATTACH=CONFIG]33423[/ATTACH]My question here: how the Enterprise Geodatabase Layer (SQL) accepts features that have error?
OK, misunderstood that part.Yes and No. ESRI already applies one of the strictest models for valid geometries in enterprise geodatabases in the industry. I am still not sure how to judge this "loop hole" you found with this layer, whether it is a bug or "by design"... I am still eager to hear more from Vince or other ESRI staff regarding this particular issue, especially since the ESRI enterprise geodatabases, not allowing Check Geometry and Repair Geometry to be run, are "supposed" to contain valid shapes. As the ArcGIS Help says in the Check Geometry page:"SDE Geodatabases automatically check the validity of each geometry when they are uploaded; therefore the Check Geometry and Repair Geometry tools are not for use with SDE."On the other hand, databases will always be kind of "open". The geometry validation as implemented by ArcSDE, is a layer "on top" of the enterprise database. You could always circumvent this by, for example, using a SQL client (e.g. SQL Server Management Studio, Oracle SQL*Plus) to write out invalid shapes and thus still cause issues.This also highlights the need (and you are already working on this!), to validate the data before loading in any conceivable way, especially if suspected "dirty" data from a third party system needs to be ingested.
�?� Correct. I didn�??t apply the �??Geometry validator�?� for the Roads layer and Boundary layer. My final layer is neither the Roads nor the Boundary but one layer that combines both Land use and Roads. This is why I didn�??t apply the �??Geometry validator�?� Roads or Boundary but I did before the �??LanduseAndRoadsPolygons_FME�?� Layer. This is the layer that is collected in the enterprise layer as it represents one urban master plan for a particular community.
�?� Topology\repair geometry\integrated could be solutions. What is horrible is that the enterprise layer accepts features with errors, and that is in turn, generates big problems such as �??two donuts or two outer shells overlap�?� and leads to deadlock.I think that the enterprise layer (SQL or Oracle) should be designed not to accept features with errors as this will lead to destroy the data.
I can't answer this Jamal, but just a number of quick observations (need to have a closer look yet):- I was able to reproduce the addition of the geometry number 51 with the geometric error to my SQL Server 2012 Express (all patched up) database using the Copy / Paste. This really is not good, but may be explained by a simple acceptance of the "geometry-as-is" by the Copy / Paste operation, and inserting it straight in the database. This screams for the ability to run Check Geometry and Repair Geometry against Enterprise Geodatabases as well, not just File Geodatabases (which isn't currently possible: the tool doesn't accept Enterprise Geodatabases as data source). I don't know if this would actually classify as a "bug" or is "as-build", maybe Vince can elaborate a bit more...- The geometry with the error is the roads polygon in the layer- As an addition to the above, I noticed, although you already build in 3 "Geometry Validator" steps in your FME model, you don't actually check and repair the road and boundary layers as the end products of your model. I would suggest adding two more "Geometry Validator" instances to the model, to tackle this problem. See the attached image.- I would also strongly suggest to run "Check Geometry" and "Repair Geometry" against the data created by FME in your File Geodatabase, before adding it to the SQL Server. And possibly also run "Integrate" and / or create a "Topology" for the layer, to check for overlapping or non-contiguous areas in the polygon layers. A Topology will tell you more than just running Integrate, as it will highlight possible issues, instead of just "fixing" them, and give you more control over what is happening or how it should be fixed.Do note that all of these tools, and especially Integrate, can lead to small shifts in the vertex coordinates of the vertices making up the geometries, so small shifts compared to the original CAD data, may occur.
This seems wise. Run Check Geometry, and possibly Repair Geometry, as often as possible in your workflow. The sooner you detect serious geometric issues, even if caused by another step in your workflow than the initial data generation in CAD, the better. The more points in your entire workflow that you run Check Geometry, the higher the chance of homing in on potential (digitization) problems and problematic data conversion steps.It would also be wise to start collecting some data on what problems occur if caused by digitization errors. You may than be able to put on paper some "best practices" and warnings concerning digitization issues, and distribute this among colleagues to make them aware of the issues. It may lead to better practices regarding digitization. The CAD colleagues may not even be aware of any issues (of course, this assumes issues are in initial data generation - which is likely - and not caused by subsequent conversion steps - less likely, but still very much possible).
We may need to apply the �??check geometry�?� before copy\paste or Import\Export\Load to have the list of incorrect features that will be deleted\repaired.
You might be able to recuperate much of the data by using the FME / Data Interoperability extension against the layer and exporting to some other non-enterprise database format, or possibly using SQL Server tools for repairing geometries.(There is a MakeValid command, but you will need SQL knowledge and I don't know if there are risks running this against an ESRI Enterprise Geodatabase, e.g. there might be issues with area / perimeter after geometries have been cleaned via SQL. Also see here and here).Other option: restore from recent backup and see if you can restore the layer by re-importing data.Last but not least: contact ESRI support... maybe a local representative with thorough ArcGIS knowledge could help you out, these kind of things are difficult to solve from a distance...
The issue of �??two donuts or two outer shells overlap�?� is escalated. Now, I�??m not able even to display the layer or export\load\import....What other options do I still have to extract my data from this enterprise layer?
2. Next, each editor will copy and paste the converted polygons form his\her local file geodatabase layer to an ENTERPRISE layer.
They are different processes. Export/Import runs the equivalent of RepairGeometry on a feature if it fails on insert and tries again. If the insert fails on the second attempt then it rejects the feature and goes on.
Precisely. This is what is confusing me the most at the moment.Our workflow is simple:1. Our CAD data (hatches) are converted to polygons using the FME. The FME stores these polygones in file geodatabase layer. Many editors do this sort of work at the same time at their local machines and their local file geodatabase.2. Next, each editor will copy and paste the converted polygons form his\her local file geodatabase layer to an ENTERPRISE layer.3. Now, this enterprise layer is copied and pasted to other file geodatabase to be published by the ArcGIS server and then to be read by a web mapping application. This is done for performance issue. Services that is published from file geodatabase are faster than those published from enterprise.Yes, I expect that all features that are living in Enterprise layers are fine. This appears not to be true as the error of �??two donuts or two outer shells overlap�?� comes up when coping from enterprise to file.How to resolve the issue of �??two donuts or two outer shells overlap�?�? the way from enterprise to file should be OK all the time. But my case is a counter example.
I am slightly surprised, I would have expected it to be the other way around: dirty data in the File Geodatabase with 44657 records, and then a certain number of records dropped on import to the Enterprise Geodatabase because of failure to comply with the (Clementini) rules and not repairable: 42769 records in the Enterprise Geodatabase.How did you get this data in the Enterprise Geodatabase? Theoretically, the situation you created shouldn't be possibly (but I guess the answer may be the FME workflow you set up for ingesting the CAD files...).I guess the next step might be to get back to the original (CAD) data, import this into a File Geodatabase first (possibly using your FME workflow, but with a changed target in the File Geodatabase instead of Enterprise Geodatabase if possible), run Repair Geometry / Integrate against the Feature Class in the File Geodatabase, and only then attempt to import the data in the Enterprise Geodatabase.But I may be missing some vital steps in your current workflow, I only have a fragmented overview based on the different threads you started.
Now I�??m really in trouble due the data flow issues between file\enterprise databases. I can�??t transfer the data in both directions. Data will be lost�?� Import\export\load data tools will apply the �??repair geometry�?� . The enterprise layer contains 44657 while the exported file layer is reduced to 42769
This is some vital information missing from the ArcGIS for Desktop Help that might be added (by the way, in general I regard ESRI's Help and documentation efforts of a very high level, the Help and whitepapers are one huge reservoir of knowledge and of great use once you acquaint yourself with the basic jargon).According to the Help, and running the Import option from ArcCatalog, the Import option is associated with the Feature Class to Feature Class tool. I don't see this "repair" step listed in the Help.
They are different processes. Export/Import runs the equivalent of RepairGeometry on a feature if it fails on insert and tries again. If the insert fails on the second attempt then it rejects the feature and goes on. This is bothgood and bad, since invalid data that can be coaxed into something thatlooks valid will pass, but then you've got garbage in your database.
They are different processes. Export/Import runs the equivalent of RepairGeometry on a feature if it fails on insert and tries again. If the insert fails on the second attempt then it rejects the feature and goes on. This is bothgood and bad, since invalid data that can be coaxed into something thatlooks valid will pass, but then you've got garbage in your database.- V
Which is why you need to study the documentation on shape validation -- It does NOT mean the same thing as applying rules to feature classes. This topology is about howactual geometry primitives work, self-referentially. Without this understanding, you will always be confused with respect to data conversion errors.- V
The issue is that two donuts or two outer shells overlap (a violation of polygon topologyrestrictions).It would help if you did some research on shape topology. I use the reference work fromwhich the Esri libraries were designed:E. Clementini, P. Di Felice, and P. van Oosterom, "A Small Set of Formal Topological Relationships Suitable for End-User Interaction," in Advances in Spatial Databases - Third International Symposium, SSD '93. vol. 692, D. Abel and B. C. Ooi, Eds. Berlin: Springer-Verlag, 1993, pp. 277-295. This will also explain what a self-intersecting simple_line boundary is (though it was theOpen GIS Consortium that named the more restrictive SIMPLE_LINE that way).- VPS: The older ArcSDE documentation has a primer on shape validation which should alsobe useful.
