I don't understand. Is there an .ecp file involved when authorizing server 10.0? I authorize using the internet, and no files are exchanged that I can see, at least. Where can I find the .ecp file?I would think that if the authorization server in redlands issues a file to me, this file will be bound to the computer from which I authorized, so it would be no use to me when reinstalling on a separate computer?
I have this same problem. I uninstall ArcGIS Server 10, but the ECP registration number on my ESRI Customer Care site still says "activated" for this ECP. When I reinstall ArcGIS Server 10, or run the ArcGIS Server 10 post install, and try to register via the internet this ECP is still "activated" and thus the registration/activation fails. Can someone at ESRI please explain this system? Must we call ESRI to unactivate the ECP everytime we need to reinstall or run the ArcGIS Server Post-Install? If so, thats not an improved licensing system but a step backwards!
I'm a little unclear on what to do when repairing.Do you authorize again or not?I seem to have used up my counters (you look like you can only reauthorize about 2-3 times) trying to repair single server after issues.Stopped authorizing and it appears my image server extension stopped working.I thought mac addresses were going to be used for 10. Why can't you authorize unlimited times for same machine?You also can't modify a provision file can you?
You can find the ecp file here: c:\program files\esri\license10.0\sysgen\keycodes. This keycodes file can be opened in notepad and saved as a .ecp extension as a backup and can be used to reauthorize ArcGIS Server on the same machine. If you need to authorize ArcGIS Server on a different machine, you will need to authorize it against ESRI Customer Service the same way your first machine was initially authorized.
I have a two authorization numbers X/Y which could be used for arcgis server 10.5.1 for one server. However I am installing arcgis server 10.4.1 in another server and both X/Y could not be used. Any course of actions?
I have the same issue , so i contacted the distributor in my country and tell me the only way to do this is contact esri to reset the license for server . i don't know if this the best practice.if any one get the solution plz tell us
