If anyone happens to get this "Error HRESULT E_FAIL has been returned from a call to a COM component" error while publishing map services in ArcGIS Pro, like I did, restarting the "PublishingTools" and "PublishingToolsEx" services via the ArcGIS Server Administrator Directory solved my issue. Hope that helps anyone who needs it.
Hi @LeonoreBehr Greetings from India!
I too had encountered this error message displayed after using the stream segmentation tool from ArcHydro. Firstly, I thought that this error has something to do with the internet connection, but after insuring the internet connection, still I was getting the same error.I tried many things from the trouleshooting from ESRI community pages. But still didnt get success. Then I just changed the filename of the output file for the stream segmentation grid and it did work. Also, the reply from @MarkBoucher to check the option from Changing the mxd properties (File>Map Document Properties) to "store relative pathnames to data sources", also seems to be fine solution. Also I am in favour of his comment on the data to be kept in C-drive. It allows the programs to run smoothly and read the pathnames of such data easily.
I am receiving this error when I open ArcGIS Pro. I am running ArcGIS Pro 2.7.0. Has anyone else had this error pop up in PRO? SOLUTION? thanks
Yes, file locks, processing extents, missing data, ... "These are a few of (Error HRESULT E_FAIL's) favorite things". [dub over this that song from "The Sound of Music"]
I haven't had this issue in a while. I created a brand new Geodatabase, as well as a Mosaic. I noticed that I would typically have this issue if I forgot to "Stop Editing" a mosaic, or if the mosaic itself had become corrupt (which happened several times, an I am not sure why).
Our organization also has upgraded to 10.6. I wish I could be more help.
My web search revealed little on this error.
It is basically the program "crying like a baby" and you have to guess what's wrong.
I think (and I could be wrong) the routine can't find any data to work with and says "Huh?" Then translates that into "HRESULT E_FAIL has been returned from a call to a COM component". If the processing extents don't coincide with the data, then this is what happens. This could be why things don't work well over the network (the link to the data gets scrambled). But then again, this is just my guess...
Check to see that your processing extent covers your data. Check/Set this in the menu "Geoprocessing>Environments>Processing Extent". On occasion, I've found that this fixes the problem.
Jonathan, did you ever find the solution? I am encountering the same issue. Tried moving all data to C drive but still get the same error message: Error HRESLT E_FAIL has been returned from a call to a om Component
Using ArcMap 10.3.1 and ArcHydro, error is occurring at Catchment Grid Delineation step
It looks like that video is no longer available. Can you perhaps offer some guidance on what it was about? I am having this issue and none of the solutions above have worked for me.
See this video may help you in your problem https://www.youtube.com/watch?v=DK34C7QScRU&feature=youtu.be
Install Visual Studio 2010 SP1 it resolve the issue
