In android arcgis samples: Esri/arcgis-runtime-samples-android: ArcGIS... - GitHub
the code such as RoutingAndGeocoding.java.
uses some files like: SanDiego.tpk, SanDiego_StreetAddress.loc and RuntimeSanDiego.geodatabase
from where I can bring these files ?
As mentioned in the Readme file (arcgis-runtime-samples-android/README.md at master · Esri/arcgis-runtime-samples-android · GitHub ) you can get the sample data that works with this specific sample by downloading from ArcGIS Online:
If you want to use your own data, you can generate TPKs and offline geodatabases yourself - you can do this either on your device (services pattern) or using ArcGIS Desktop if you have that (Desktop pattern). I would start by reading this topic:
Create an offline map—ArcGIS Runtime SDK for Android | ArcGIS for Developers
Hope that helps,
Shelly
and I want to get files for different region !
