I am trying to build a model in Arc Desktop 10 where the sum of two fields is equal to the third field. For example, I have a line with various segments. In the attribute table, one of the fields is the Begin_Measure field which is 0 for the first segment. The second field is Segment_Length which has a value (let's say 10). The third field is the End_Measure, which should be the sum of the first two (in this case, 10). The value of the first End_Measure becomes the value of the second Begin_Measure, and so on.The real problem I'm having with this is that I do not have values for the Begin_Measure for any but the first segment, and I am having to run the Field Calculator for each segment. Is there a way to build a model that will calculate the fields for each segment automatically?
