When entering values into double or single type fields in Collector 20.2 for Android, the keyboard doesn't have the decimal point. I'm using a Samsung Galaxy Tab Active 2 running Collector 20.2.
The fields support the values-- you can paste in periods from the clipboard-- but that's not a real solution. What gives?
This is a limitation of the default keyboard provided on some Android devices. You can install a 3rd party keyboard like GBoard and set it as the default keyboard for the device. which will display the decimal button for these fields during entry.
Thanks for the tip. I've done so.
Thanks, Doug. Installing GBoard and setting it as the default keyboard worked for me-- though, candidly, I'm not super excited that Collector requires a workaround for something as basic as data entry.
FYI there is a bug logged (BUG-000131801) for this through Tech Support. I encourage you to contact them and get yourself attached so we can effectively gauge how many are impacted by this.
Colin
Thank you for the workaround. I will try it. I am still confused why the decimal point is available on the exact same android devices while using Classic Collector.
