I created a loop to zoom to every shape in a shapefile and export that particular extent. The only problem is that the jpeg is given the number of the row as name. I want to give it the name of a field in de dbf. Does anybody have an idea how to do that?
import arcpy from arcpy import env from arcpy import mapping mxd = arcpy.mapping.MapDocument(r"C:\gisbestanden\pythontest\test13.mxd") df = arcpy.mapping.ListDataFrames(mxd)[0] fc = r"Z:\kaarten\COROP\coropmultipart.shp" count = str(arcpy.GetCount_management(fc)) x = 0 while x < int(count) + 1: rows = arcpy.SearchCursor(fc, "fid = " + str(x)) for row in rows: xmin = row.shape.extent.XMin ymin = row.shape.extent.YMin xmax = row.shape.extent.XMax ymax = row.shape.extent.YMax # get the field contents to name the file filename = row.getValue("NAMEFIELD") # or: row.NAMEFIELD df = arcpy.mapping.ListDataFrames(mxd)[0] newExtent = df.extent newExtent.XMin, newExtent.YMin = xmin, ymin newExtent.XMax, newExtent.YMax = xmax, ymax df.extent = newExtent # use the field contents in the filename mapping.ExportToJPEG(mxd, r"C:\gisbestanden\pythontest\gemeentekaart\JPEG_{0}.jpg".format(filename)) print "successfully printed JPG" x += 1
Hi Curtis,
I'm new to Python, but this is exactly what I need to do - run through my shapefile (poly) and zoom to each polygon within and export to JPEG. I've copied your script, but keep getting the attribute error 'Extent' object has no attribute 'Xmin'. My shapefile consists of 4 fields (FID, Shape, Unit, Hectares), am I missing something?
Nate
