I'm using the polygon drawing code here to draw my own polygon retrieved using AJAX.This is for a web application designed to run in the UK, so the points retrieved are eastings and northings.However I don't understand how to get ESRI ArcGIS to display polygons using eastings and northing are points.I've been looking through the documentation and examples, but I'm struggling to find anything that can help me.My code is as follows: var points = new Array(); var csv = result.Value.split(','); // CSV of eastings and northings for( var i = 0; i < csv.length; i+=2){ points[points.length] = new esri.geometry.Point(csv, csv[i+1]); } // Draw polygon var polygon = new esri.geometry.Polygon(); polygon.addRing(points); polygon.spatialReference = new esri.SpatialReference({ wkid: 27700 }); // British National Grid // Add the polygon to map var symbol = new esri.symbol.SimpleFillSymbol().setStyle(esri.symbol.SimpleFillSymbol.STYLE_SOLID); polygonGraphic = new esri.Graphic(polygon, symbol); map.graphics.add(polygonGraphic);
Any help would be very much appreciatedThanksPeter Bridger
