How do you manage graphics with the ArcGIS JavaScript API?
Specifically, I want to delete all graphics that intersect a polygon. How do I do that?
I have graphics in Feature Layers.
Thanks!
Jerry,
You would loop through the Graphics Layers graphics to see if the graphics.geometry is contained in the test polygon. Polygon class has a contain method that take a geometry as a parameter. If the polygon contains the geometry then you use the GraphicsLayers.remove method that take a graphics as its parameter. Hope this helps.
Robert,
is there any sample regarding graphic overlap checking...?!
thanks,
