Prior to 10 it was on the Fields tab and was called Primary Display Field
Actually didn't display expressions come in at 10, so it uses a display expression.
TedWe introduced the new Wizard in 10. The reason it stays on top is to ensure that it does not get "lost". I.e. it gets moved off the page or something else gets on top of it. Also, because it is an interactive tool, it should be the focus of attention. I.e. Add Field tool can be run before or after the Wizard is used. We do take note of your concerns and we'll see if we could change it in some or other way.To change the order of which field comes first. Setting the field to be used is not a Geostats function but an ArcGIS function and it has been around for a while.- Right click on the Feature layer in the TOC- click on Layer and then on the Display tab- under the Display Expression section select the Field (note for Geostats it must be numeric)- hit OKThat field will be the default field in the ESDA tools and also in the Wizard.
