It's been a while since I've used the JavaScript API, so I'm fairly rusty. I'm in the process of updating several of our maps to the newest API and making the layout more mobile-friendly.
I am using the LayerList with Legend sample code. I'd like to hide two of my three layers from the LayerList. They essentially make up my basemap. Here's my layerlist code currently:
<SPAN class="keyword token">var</SPAN> layerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
container<SPAN class="punctuation token">:</SPAN> document<SPAN class="punctuation token">.</SPAN>createElement <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"div"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
listItemCreatedFunction<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> item <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>item<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">!=</SPAN> <SPAN class="string token">"group"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// don't show legend twice</SPAN>
item<SPAN class="punctuation token">.</SPAN>panel <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"legend"</SPAN><SPAN class="punctuation token">,</SPAN>
open<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> llExpand <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Expand</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
content<SPAN class="punctuation token">:</SPAN> layerList<SPAN class="punctuation token">.</SPAN>domNode<SPAN class="punctuation token">,</SPAN>
expandIconClass<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esri-icon-layer-list"</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>llExpand<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>And my layers:
<SPAN class="comment token">// Add state feature layer</SPAN>
<SPAN class="keyword token">var</SPAN> stateLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"http://myURL/States/MapServer/0"</SPAN><SPAN class="punctuation token">,</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>stateLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Add counties feature layer</SPAN>
<SPAN class="keyword token">var</SPAN> countiesLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"http://myURL/AlabamaCounties/MapServer/0"</SPAN><SPAN class="punctuation token">,</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>countiesLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Add WFF districts feature layer</SPAN>
<SPAN class="keyword token">var</SPAN> WFFdistrictsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"http://myURL/WFFDistricts/MapServer/0"</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Wildlife and Freshwater Fisheries Districts"</SPAN>
mapMain<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>WFFdistrictsLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I'd like to remove the stateLayer and countiesLayer from the layerlist. I believe using listMode will be my best option. I've followed the info in the thread, https://community.esri.com/thread/232289-remove-layers-from-the-layerwidget , with limited success. I've been able to hide one layer, but not both.
Any suggestions on how to best hide multiple layers?
Thanks in advance for your time!
Ashley
