import arcgisscripting, smtplib, os, sys, traceback from email.MIMEMultipart import MIMEMultipart from email.MIMEBase import MIMEBase from email.MIMEText import MIMEText from email.Utils import COMMASPACE, formatdate from email import Encoders gp = arcgisscripting.create(9.3) #********************************************************************** # Description: # Emails a file. File is assumed to be a zip file. Routine either attaches # the zip file to the email or sends the URL to the zip file. # # Parameters: # 1 - File to send. # 2 - Email address to send file. # 3 - Name of outgoing email server. # 4 - Output boolean success flag. #********************************************************************** def send_mail(send_from, sendto, subject, text, f, server, sendZip = False): # Construct the message # msg = MIMEMultipart() msg['vince@xyz.com'] = send_from msg['grill@with.com'] = COMMASPACE.join(sendto) msg['Date'] = formatdate(localtime=True) msg['Subject'] = subject msg.attach( MIMEText(text) ) part = MIMEBase('application', "dbf") # Change if different file type sent. part.set_payload( open(f,"rb").read() ) Encoders.encode_base64(part) part.add_header('Content-Disposition', 'attachment; filename="%s"' % os.path.basename(f)) msg.attach(part) smtp = smtplib.SMTP(server) smtp.sendmail(send_from, sendto, msg.as_string()) smtp.close() ## Arguments # Path to dbf dbffile = sys.argv[1] # Email sendto = sys.argv[2] # IP address eMailServer = sys.argv[3] subject = "DBF file attached" text = "Attached is the dbf file you requested." sendZip = True send_mail("200.110.100.1", sendto, subject, text, dbffile, eMailServer, sendZip) print "Sent dbffile to "+sendto+" from 200.110.100.1"
