How to label features in FeatureCollectionTable? I am using ArcGIS Runtime for Qt. Kindly share a sample code if possible.
Thanks in advance.
QList<Field> fieldNames; fieldNames.push_back(Field::createText(NAME_FIELD, NAME_FIELD, NAME_LENGTH)); labelFeatureTable = new FeatureCollectionTable(fieldNames, GeometryType::Point, spatialReference, this);
// empty point which is the anchor marker for the label SimpleMarkerSymbol *simpleSym = new SimpleMarkerSymbol(this); simpleSym->setSize(0.0);
TextSymbol* textSym = new TextSymbol("text", color, 12, HorizontalAlignment::Left, VerticalAlignment::Middle, this);
FeatureLayer *labelLayer = labelFeatureTable->featureLayer(); if (labelLayer != NULL) { LabelDefinitionListModel* labelDefinitions = labelLayer->labelDefinitions(); if (labelDefinitions != NULL) { QJsonObject obj;QJsonDocument textDoc = QJsonDocument::fromJson( textSym->toJson().toUtf8());// https://developers.arcgis.com/web-map-specification/objects/labelingInfo/ obj.insert(QString("symbol"), textDoc.object());QString labelExpression = QString("$feature.") + NAME_FIELD; QJsonObject labelExpressionObj;labelExpressionObj.insert(QString("expression"), labelExpression); obj.insert(QString("labelExpressionInfo"), labelExpressionObj); obj.insert(QString("deconflictionStrategy"), QString("none")); obj.insert(QString("labelPlacement"), QString("esriServerPointLabelPlacementAboveRight")); obj.insert(QString("maxScale"), 0); obj.insert(QString("minScale"), 0); obj.insert(QString("useCodedValues"), true); QJsonDocument newDoc(obj);Esri::ArcGISRuntime::LabelDefinition* newlabelDef = Esri::ArcGISRuntime::LabelDefinition::fromJson( newDoc.toJson(QJsonDocument::Indented));if (newlabelDef != NULL) {labelLayer->labelDefinitions()->append(newlabelDef);} else { cout << "newlabelDef == NULL" << endl; } } else { cout << "labelDefinitions == NULL" << endl;} } else { cout << "labelLayer == NULL" << endl; }
Apparently my indentation did not carry over but hopefully this helps. I had some issues when I first started programming this so that is why I NULL check everything. I used QJsonObject so I wouldnt need to be careful escaping quote characters in text based json.
Thanks for your reply.
Labels got displayed, but in my case the labels will be always moving and when one label overlaps with other, only one label is displayed and rest of the overlapped labels will be hidden. Is it possible to change the position of the labels if it gets overlapped while moving?
deconflictionStrategy has a few different options, I recommend going into the documentation for the json magic https://developers.arcgis.com/web-map-specification/objects/labelingInfo/ and seeing what the different options are and experimenting with them. I think there also is a priority argument where you can specify which labels should be preferably displayed over others. For that you would want to set up another field in your table and then have multiple labelDefinitions using a where statement for each one.
