I am having issues loading the Measurement Widget. I receive errors in the console that indicate that the widget is already loaded. I found past threads on GeoNet concerning using dojoConfig and parser.parse at the same time. I went through my code and as far as I can see I am only using parser.parse.
I've attached a couple images for reference. The first shows the errors I'm receiving in the console and the second shows the widget loaded without all components. I've also attached my html and the appropriate js file for reference, however you can work with the application at this location: Town of Queensbury Interactive Mapper
Any help is appreciated.
George Hilton
Town of Queensbury, NY
George,
The whole issue is the fact that your accordion container is hidden when you are trying to add the measure widget to it. The best workaround for this is to not create the measure widget until the accordian is shown (be sure to remove the other locations of code where you were adding the measure widget before):
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">showhideleg</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> legwin <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"rightPane"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//var legwin2 = document.getElementById("rightpane-wrapper");</SPAN> <SPAN class="comment token">// var viz = legwin.style.visibility;</SPAN> <SPAN class="comment token">// var viz2 = legwin2.style.visibility;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>ishidden <SPAN class="operator token">==</SPAN> <SPAN class="string token">"TRUE"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//console.log(ishidden);</SPAN> legwin<SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>visibility <SPAN class="operator token">=</SPAN> <SPAN class="string token">"visible"</SPAN><SPAN class="punctuation token">;</SPAN> registry<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"accord"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">selectChild</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"legendPane"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> ishidden <SPAN class="operator token">=</SPAN> <SPAN class="string token">"FALSE"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>measurement<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//Create Measurement Widget/Tool</SPAN> measurement <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Measurement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> defaultLengthUnit<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFeet"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"measureDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// measurement.on("measure-end", function (evt) {</SPAN> <SPAN class="comment token">// clrbuff.disabled = false;</SPAN> <SPAN class="comment token">// this.setTool(evt.toolName, false);</SPAN> <SPAN class="comment token">//});</SPAN> measurement<SPAN class="punctuation token">.</SPAN><SPAN class="token function">startup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//End Add Measure Widget/Tool</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#rightPane"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">toggle</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">//RESET THIS ONLY IF NEED BE</SPAN> <SPAN class="comment token">//legwin.style.visibility = "visible";</SPAN> <SPAN class="comment token">//registry.byId("accord").selectChild("legendPane", true);</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Perfect !!! As usual, thank you very much for your assistance !
George
I see what happened, lower in your load.js, you have more measurement functions that have been commented out.
I'm showing that section uncommented in my working code and through the console. I apologize if I sent a previous copy of load.js. Here is the current working code: load.js
In your load.js the measurement section is commented out.
Could you uncomment out the measurement part so we can see the errors from it.
