When I try to change the symbology for a polygon layer, ArcGIS Pro 2.2.0 is using old values that don't exist anymore and ignoring new values. In the attached screen show, when I add all the Values for the field called "Type" it is symbolizing values like "Overhead Fiber" and "Road" and the misspelled "Tranmsission". These values no longer exist in the data. Also, in the data there are values "Access" and "Commitment" that ArcGIS Pro does show as a value. It seems like ArcGIS Pro is using using some old cached version of the data. I have tried deleting all the cache files in C:\Users\xyz\AppData\Local\ESRI\Local Caches. That didn't work. I'm stuck. It works perfectly fine in ArcMap.
Thanks for any help you can give.
