Went to upgrade to 2.7 and am getting an error as soon as I open startup (attached). If I press a key to continue it just closes. I haven't been able to find anyone else with this error..... any ideas? Thanks!
Kimberly,
So this is a new 2.7 install? Did you ever get the screen where is asked you for your portal url?
Sorry, should have given more info in original question. The error was from startup on 2.6 to download an app before beginning the upgrade to 2.7.
Did you install 2.6 and 2.7 in different folders on your machine?
I keep all versions in folders that are housed in the same folder.
OK, I was wanting to make sure you did not attempt to overwrite the same folder. Hmm... So your 2.6 worked fine until when?
