I am learning from the trial version, is the lot min area and lot max area in acres?
Ok, I haven't gotten to that tutorial yet so I will investigate. Thank you for your help!
I don't know about preference settings but if you're running the subdivision tool you can do that via python and build in a conversion factor.
Ben,
I assume that the coord system that i am importing is adjusting to the metric system when i import it. But to answer your question the raw data that I work with is in feet and acres, not meters.
Is there a way to change the default through preferences or something to feet and acres?
What about if your coord system is 'Raw data in feet' or another non-metric system?
All units in CE are meters, so
Length = meters
Area = meters squared
Volumes = meters cubed
Hooray for metric. Down with the dark side.
