I have a original tif file which has values from 2 to 28. From that original tif file, I am extracting cells having value >=10 using the following code. The code is working. However, when I open the new extracted tif file in GIS, I found that the cell values range from 10 30 instead of 10 to 28. I would really appreciate any help/ suggestion!
The code is provided below:
import arcpy, os
from arcpy import env
from arcpy.sa import *
#To overwrite output
#Set environment settings
env.workspace = "C:/Subhasis/Highland/Project/Python_data"
outws="C:/Subhasis/Highland/Project/Python_data/HSA_10"
#checkout ArcGIS spatial analyst extension license
inraster = arcpy.ListRasters("*", "TIF")
for i in inraster:
flds = ("VALUE", "COUNT")
dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(i, flds)}
sumcnt = sum(dct.values())
dct1 = {k:v for (k,v) in dct.items() if k >= 10}
sumcnt1 = sum(dct1.values())
percentage=(float(sumcnt1)/float(sumcnt))
print i,percentage
newraster = ExtractByAttributes(str(i), "VALUE>=10")
outname=os.path.join(outws,str(i))
newraster.save(outname)
