Is the start/end time fields defined based on a field of type date? Even though ArcMap will allow defining start/end time fields based on non-date fields, REST only supports time defined based on a date field.
it will get about 1 out of the 30 rasters in the catalog as you change the time range around.
We're having the same issue, has anyone come up with a resolution?v10 sp1~Naomi
While it is a bug for sure that these are not showing up, all we had to do was create pyramids for the rasters and then they would show up. For some reason server needs those pyramids there which I had not generated for this particular catalog.
