I'm working with a set of 88 counties in Ohio, and I need to cluster them into groups of 3 based on minimum aggregate distance between each possible cluster of 3 (I created polygon centroids for each county). This will be done without replacement. Once a county is assigned to one cluster, it is not available for others.Put another way, if there is A, B, C, and D in close proximity to one another, does A/B/C or B/C/D create "tightest" group based off sum of the distances between A-B, B-C, and A-C versus B-C, C-D, and B-D.I am aware of the Grouping Analysis tool in version 10.1 (not positive that would do the trick...), but unfortunately I do not currently have access to that platform.Help please! Thanks in advance.
#------------------------------------------------------------------------------- # Name: OHIO.py # Purpose: group point data OHIO # Author: Xander Bakker # Created: 16-10-2013 #------------------------------------------------------------------------------- def main(): print "Loading libs (arcpy)" import arcpy import math print "Libs (arcpy) loaded..." fc = r'C:\Project\_Grouping\fgdb\Grouping.gdb\OHpntSP1' # I assume that field exists and is of type integer fldOut = 'group01' maxOID = 0 dict1 = {} fields = ['OID@','SHAPE@X','SHAPE@Y'] with arcpy.da.SearchCursor(fc, fields) as cursor: for row in cursor: OID = row[0] if OID > maxOID: maxOID = OID X = row[1] Y = row[2] XY = "{0}#{1}".format(X,Y) if dict1.has_key(OID) == False: dict1.update({OID:XY}) del cursor del row print "Loop ready, dict filled..." # loops group = 0 dictSol = {} dictOIDused = {} for id1 in range(1,maxOID-2): if dictOIDused.has_key(id1) == False: minDist = 999999 minSol = '' for id2 in range(id1+1,maxOID-1): if dictOIDused.has_key(id2) == False: for id3 in range(id2+1,maxOID): if dictOIDused.has_key(id3) == False: XY1 = dict1[id1] XY2 = dict1[id2] XY3 = dict1[id3] X1 = float(XY1.split('#')[0]) Y1 = float(XY1.split('#')[1]) X2 = float(XY2.split('#')[0]) Y2 = float(XY2.split('#')[1]) X3 = float(XY3.split('#')[0]) Y3 = float(XY3.split('#')[1]) sumDist = getSumDist(X1,Y1,X2,Y2,X3,Y3) if sumDist < minDist: minSol = '{0}#{1}#{2}'.format(id1,id2,id3) minDist = sumDist else: # skip, id3 already in use pass else: # skip, id2 already in use pass # end of loop through id2, so solution is available group += 1 dictOIDused.update({int(minSol.split('#')[0]): group}) dictOIDused.update({int(minSol.split('#')[1]): group}) dictOIDused.update({int(minSol.split('#')[2]): group}) # print "minSol={0} and minDist={1}".format(minSol,minDist) else: # skip, id1 already in use pass # update cursor fields = ['OID@',fldOut] with arcpy.da.UpdateCursor(fc, fields) as cursor: for row in cursor: id = row[0] if dictOIDused.has_key(id): group = dictOIDused[id] else: group = 99 row[1] = int(group) cursor.updateRow(row) del row del cursor print "ready..." def getSumDist(X1,Y1,X2,Y2,X3,Y3): import math d1 = math.hypot(X2 - X1, Y2 - Y1) d2 = math.hypot(X3 - X1, Y3 - Y1) d3 = math.hypot(X3 - X2, Y3 - Y2) return d1 + d2 + d3 if __name__ == '__main__': main()
