Hello,I get the following exception :"Failed to create a 'LocalFeatureService' for editing as the service with the same path is already running as an instance of 'LocalMapService' which does not support editing".It happens in several occasions.For instance, when I'm instatiating a new editable feature layer after using a QueryTaskor, as shown below, when instatiating a new editable feature layer after instantiating a non-editable layer.
ArcGISLocalFeatureLayer ReadOnlyFeatureLayer = new ArcGISLocalFeatureLayer(@C:\Data\Map.mpk, 0);
ReadOnlyFeatureLayer.ID = "Streets";
ReadOnlyFeatureLayer.Editable = false;
_mapControl.Layers.Add(ReadOnlyFeatureLayer);
ArcGISLocalFeatureLayer EditableFeatureLayer = new ArcGISLocalFeatureLayer(@C:\Data\Map.mpk, 1);
EditableFeatureLayer .ID = "Trees";
EditableFeatureLayer .Editable = true;
_mapControl.Layers.Add(EditableFeatureLayer );
What am I doing wrong here ? Can't I use editable and not editable layers on the same mpk ? I would appreciate your help.Regards,Nir
