HI,
I have been asked to provide some data that can be read in GIS (ARCVIEW). Is it not reading a regular .gdb data?
If not, any suggestion? What I have is just an .gdb. Can I convert the data in some how?
Many thanks,
F
Iam trying. it takes ages to do it. almost one hour to get 1% done just for one of the raster. I have more then 1..
Did you check the Raster Catalog to Raster Dataset option that I mentioned?
ArcMap 10.2. How bizarre is this?
Try converting Raster Catalog to Raster Dataset. Save it with .tif or .img extension.
What version of ArcMap are you using? I am getting the following options of saving the Raster in following formats when my output location is a basic folder. I am using ArcMap 10.1.
So it is a Side scan sonar raster. Please see below
A DBF option will come when you are saving a table. Are you sure you are exporting the Raster data? Could you provide screenshots?
Thanks. I have tried to follow the instruction in the provided link, but when I try to export, it seems the only way it saves it is .dbf so it doesn't make the job
Open the respective image in ArcMap > Right-click the layer > Export.
Save the raster in a basic folder (not in a geodatabase) in either *.tif or *.img format.
FAQ: What are all the file extensions related to ArcView?
Exporting a raster in ArcMap
Thanks. do you know what about the raster I have in my .gdb?How can I export?
Cheers
If you have ArcMap (Standard/Advanced license), you could export the data from File Geodatabase (*.gdb) to shapefiles. ArcView should be able to read shapefiles.
