Which would you rather learn, Python, C#, or C++? Your only batch optionsare ArcPy, ArcObjects, and FGDB API (the latter two would require hundredsto thousands of lines of code, while Python would only require dozens).It would only take a few hours to learn enough ArcPy to start this.Don't bother with even looking at PGDB (size and compatibility). I would strongly discourage exceeding 20Gb in a a single FGDB table (too manyeggs in one basket). It you're targeting ArcSDE, then don't bother mergingFGDBs; do try to load either across or up/down tiles, to reduce spatialfragmentation.I started writing a standalone tool to transfer FGDB tables to ArcSDE but Microsoft library compatibility issues (static v. dynamic) made for more work than I was willing to take on. My fallback plan was to export FGDB to ASCII, which then could be quickly bulk-loaded into ArcSDE with 'asc2sde', but I haven't have time to mess with that either.- V
What are you combining these file geodatabases into? Another FGDB? How largeare you expecting the resulting table (in rows and Gb)? Are you expecting to jointhe features at tile boundaries? Is there a naming system which will allow you toknow the tile location without polling the features?Python can of course be used to append feature classes, but with the volume involved,you'll probably need a mechanism that will permit interruption and resumption of theload cascade process.Looks like a TANSTAAFL situation to me.- V
