If this issue occur in Shapefile, you may try deleting the spatial index from the Properties of the shapefile.ArcCatalog > Shapefile properties > Indexes Tab > Spatial Index > Delete and then Add > Apply the changesIf this occurs in a File Geodatabase, you may try recalculating the spatial index from the Properties of the Feature class.ArcCatalog > Feature class Properties > Indexes Tab > Spatial Index > Recalculate > Apply the changesArcCatalog > Feature class Properties > Indexes Tab > Spatial Index > Delete and Recalculate > Apply the changesUnfortunately for a personal geodatabase feature classes, there is no button to recalculate the spatial index as in File GDB or Shapefile. However the Spatial Index can be recalculated by exporting the feature class again to the same geodatabase or to a different geodatabase.ArcCatalog > Right-click on feature class > Export > To Geodatabase (single)orArcToolbox > Conversion tools > To Geodatabase > Feature class to Feature ClassHope this helps. If you further face any issues, I would recommend to contact Technical Support for further assistance.
I'm having the same issue - features are digitized at a certain scale - then when I zoom out they dissapear! I'm working with a personal geodatabase and Arc cannot delete the spatial index of a personal geodatabase (someone suggested this as a fix on the forum). Can anyone help!
My solution is to delete the spatial index either in ArcCatalog>Feature Properties>Indexes, or using the Remove Spatial Index tool in ArcToolbox.
Using ArcGIS 10 SP1Interested to see if other's having these problems are using shapefiles or gdb's; if the latter, what version of gdb?
Featurelayer might be scaled or something ?
I'm having the same issue. Features that I just digitized are disappearing. When I zoom out they re-appear. I don't have any scale dependencies set. ArcMap version 10 SP1. Anyone know what is going on?
