<Msg time='2010-06-21T17:41:36' type='ERROR' code='100005' target='California.MapServer' methodName='MapServer.GetTileCacheInfo' machine='purehate' process='1868' thread='3548' elapsed='0.00012'>Method failed.HRESULT = 0x80004005 : Unspecified error .</Msg>
<ServerObjectConfiguration> <Description>Map Description</Description> <Properties> <FilePath>D:\Maps\California.mxd</FilePath> <OutputDir>\\PUREHATE\arcgisoutput</OutputDir> <VirtualOutputDir>http://purehate/arcgisoutput</VirtualOutputDir> <MaxImageHeight>2048</MaxImageHeight> <MaxRecordCount>500</MaxRecordCount> <MaxBufferCount>100</MaxBufferCount> <SupportedImageReturnTypes>URL</SupportedImageReturnTypes> <IsCached>false</IsCached> <CacheOnDemand>false</CacheOnDemand> <IgnoreCache>false</IgnoreCache> <ClientCachingAllowed>true</ClientCachingAllowed> <CacheDir>c:\arcgisserver\arcgiscache\California</CacheDir> <SOMCacheDir>c:\arcgisserver\arcgiscache</SOMCacheDir> </Properties> <Extension> <TypeName>KmlServer</TypeName> <Enabled>false</Enabled> <Properties> <ImageSize>1024</ImageSize> <Composite>true</Composite> <Dpi>96</Dpi> <UseNetworkLinkControlTag>false</UseNetworkLinkControlTag> <MinRefreshPeriod>30</MinRefreshPeriod> <LinkDescription></LinkDescription> <LinkName></LinkName> <Message></Message> <UseDefaultSnippets>false</UseDefaultSnippets> <EndPointURL>http://purehate/ArcGIS/services/Californiasdf/MapServer</EndPointURL> </Properties> <Info> <WebEnabled>true</WebEnabled> <WebCapabilities>SingleImage,SeparateImages,Vectors</WebCapabilities> </Info> </Extension> <Extension> <TypeName>MobileServer</TypeName> <Enabled>false</Enabled> <Properties> </Properties> <Info> </Info> </Extension> <Extension> <TypeName>NAServer</TypeName> <Enabled>false</Enabled> <Properties> </Properties> <Info> </Info> </Extension> <Extension> <TypeName>WCSServer</TypeName> <Enabled>false</Enabled> <Properties> </Properties> <Info> </Info> </Extension> <Extension> <TypeName>WFSServer</TypeName> <Enabled>false</Enabled> <Properties> </Properties> <Info> </Info> </Extension> <Extension> <TypeName>WMSServer</TypeName> <Enabled>false</Enabled> <Properties> </Properties> <Info> </Info> </Extension> <Recycling> <Start>00:00</Start> <Interval>86400</Interval> </Recycling> <Info> <WebCapabilities>Map,Query,Data</WebCapabilities> <WebEnabled>true</WebEnabled> </Info> <IsPooled>true</IsPooled> <MinInstances>1</MinInstances> <MaxInstances>2</MaxInstances> <InstancesPerContainer>1</InstancesPerContainer> <WaitTimeout>60</WaitTimeout> <IdleTimeout>-1</IdleTimeout> <UsageTimeout>600</UsageTimeout> <CleanupTimeout>30</CleanupTimeout> <StartupTimeout>300</StartupTimeout> <Isolation>high</Isolation> <StartupType>automatic</StartupType></ServerObjectConfiguration>
in fact the service is not cached..its a dynamic map service,,i forgot mentioning something very important, im publishing map on the fly through a webserivce, the map is published with no problem, shows in ADF map control, but rest is causing problem, is there anything im missing ??if i publish map through Arccatalog or Server Manager everything works fine.
serverObjConfig = null; //create map server object serverObjConfig = (IServerObjectConfiguration3)this.soAdmin.CreateConfiguration(); serverObjConfig.Name = newMapServiceName; serverObjConfig.Description = newMapServiceDescription; serverObjConfig.TypeName = "MapServer"; serverObjConfig.IsPooled = true; serverObjConfig.MinInstances = 1; serverObjConfig.MaxInstances = 1; serverObjConfig.WaitTimeout = 10; serverObjConfig.UsageTimeout = 120; serverObjConfig.IsolationLevel = esriServerIsolationLevel.esriServerIsolationHigh; //root serverobjectconfiguration props ESRI.ArcGIS.esriSystem.IPropertySet2 propSet; propSet = (ESRI.ArcGIS.esriSystem.IPropertySet2)serverObjConfig.Properties; propSet.SetProperty("FilePath", mxdFileName); propSet.SetProperty("SupportedImageReturnTypes", "URL"); propSet.SetProperty("OutputDir", "c:\\arcgisserver\\arcgisoutput"); propSet.SetProperty("VirtualOutputDir", "http://***********/arcgisoutput/"); propSet.SetProperty("MaxImageHeight", "2048"); propSet.SetProperty("MaxRecordCount","500"); propSet.SetProperty("MaxBufferCount", "100"); propSet.SetProperty("MaxImageWidth", "2048"); propSet.SetProperty("IsCached", "false"); propSet.SetProperty("CacheOnDemand", "false"); propSet.SetProperty("IgnoreCache", "false"); propSet.SetProperty("ClientCachingAllowed", "true"); //recycling properties IPropertySet2 recyclingSet = (IPropertySet2)serverObjConfig.RecycleProperties; recyclingSet.SetProperty("StartTime", "00:00"); recyclingSet.SetProperty("Interval", "86400"); //enable web access ESRI.ArcGIS.esriSystem.IPropertySet2 infoSet; infoSet = (ESRI.ArcGIS.esriSystem.IPropertySet2)serverObjConfig.Info; infoSet.SetProperty("WebEnabled", "true"); infoSet.SetProperty("WebCapabilities", "Map,Query,Data");
